Clears flap statistics for routes to specified neighbors.
| all | Specifies flap statistics for all routes. |
| remoteaddr | Specifies the IPv4 or IPv6 address of a BGP neighbor. |
| ipv4-unicast | Specifies the IPv4 unicast address family. |
| ipv4-multicast | Specifies an IPv4 multicast address family. |
| ipv6-unicast | Specifies the IPv6 unicast address family. |
| ipv6-multicast | Specifies an IPv6 multicast address family. |
| vpnv4 | Specifies the VPNv4 address family for Layer 3 VPN support. |
| rd_value | Specifies the Route Distinquisher (RD) value for the Layer 3 VPN routes for which you want to clear flap statistics. |
| no-advertise | Specifies the no-advertise community attribute. |
| no-export | Specifies the no-export community attribute. |
| no-export-subconfed | Specifies the no-export-subconfed community attribute. |
| community_num | Specifies a community number. |
| AS_Num | Specifies an autonomous system ID (0-65535). |
| Num | Specifies a community number. |
| any | Specifies all routes with a given or larger mask length. |
| netMaskLen | Specifies a subnet mask length (number of bits). |
| networkPrefixFilter | Specifies an IP address and netmask. |
| exact | Specifies an exact match with the IP address and subnet mask. |
If no address family is specified, IPv4 unicast is the default.
You must specify an IPv6 address family for an IPv6 peer, because an IPv6 peer does not support the default IPv4 unicast address family. Similarly, if you specify an IPv4 peer and an address family in the command, an IPv4 address family must be specified.Use this command to clear flap statistics for a specified BGP neighbor.
The option network any / netMaskLen clears the statistics for all BGP routes whose mask length is equal to or greater than maskLength, irrespective of their network address.
The option network any / netMaskLen exact clears the statistics for all BGP routes whose mask length is exactly equal to maskLength, irrespective of their network address.
To clear flap statistics on Layer 3 VPNs, you must configure this feature in the context of the MPLS-enabled VR; this feature is not supported for BGP routes on the CE (VRF) side of the PE router.
This command applies to the current VR or VRF context.
The following command clears the flap statistics for a specified neighbor:
clear bgp neighbor 10.10.10.10 flap-statistics all
The netMaskLen options were added in ExtremeXOS 11.0.
Support for IPv6 in BGP was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
